[GRASSLIST:2286] Re: output shapefiles - options?
Radim Blazek blazek at itc.it
Mon Jan 19 12:25:00 EST 2004
Which type pricesely? 'char' should be supported.
Radim
On Monday 19 January 2004 15:54, David Orme wrote:
> Hi,
> I'm working with a series of vector files in Grass 5.7 which I need to
> export to shapefiles. The geometry is stored as native grass files and
> the attributes are stored in a PostgreSQL database. I've tried using
> v.out.ogr but there is a problem with exporting attributes with
> character data types (all the character attributes are fixed length) :
> > WARNING: pg driver: column 'sm_name', type 0 is not supported
> I can think of a number of possible ways forward - getting ODBC working
> and connecting to the pg table that way, using a PostGIS database to
> store geometry and using the pgsql2shp dumper program.
> I've tried working with postgis - one problem is I can't get
> pg.postgisdb to create a database: I've pointed to all the correct
> files (incidentally, pg.posgisdb seems to be hard coded to look for
> libpostgis files in ./lib/contrib - I had to create this folder and
> link in the libpostgis files in from their installed location in ./lib)
> but get the following:
> > /usr/local/grass57/scripts/pg.postgisdb: line 199: createdb: command
> > not found
> I _can_ connect to an existing postgis db created within psql and new
> vector files can be created in that database without problem. The
> problem is that the geometry table contains linestrings for the areas
> and also points for the label points and pgsql2shp can't write both
> types into one file and currently doesn't have the option to
> selectively export geometry types.
> Can anyone suggest fixes / tell me if ODBC will export the character
> columns / suggest another alternative?
> Many thanks,
> David Orme
