[GRASSLIST:2300] Re: BGC GRASS module
chiara.sboarina at katamail.com chiara.sboarina at katamail.com
Wed Jan 21 03:04:36 EST 2004
Kirk,
you are right I modified Biome-BGC of Running et al. . I simplified it a lot because my aim is to calculate the amount of C stocked in a year by forest of a region. So I chose as out put only totalc, vegc, soilc and litterc. I removed the spinup simulation not to weight down the module so the user must have many initialization parameters. Now I'm testing the module to see if it works. If you need more informations just tell me and I will try to answer you.
Bye
Chiara
 Da: Kirk R. Wythers <kwythers at umn.edu>
 Data: Tue, 20 Jan 2004 13:17:12 -0600
 A: "chiara.sboarina at katamail.com" <chiara.sboarina at katamail.com>
 Oggetto: Re: BGC GRASS module
Chiara,
I'd be interested to hear more about your module. What was it designed
to do? I assume you are talking about the BGC family of ecosystem
models (Running et al.).
Regards,
Kirk
On Jan 19, 2004, at 1:55 AM, chiara.sboarina at katamail.com wrote:
> Hi Scott,
> I succeded to compile the module last week but I haven't tried it yet
> because I need to prepare the input maps and data. As soon as I test
> it I make you know how it works. My aim is to calculate the amount of
> carbon stocked by the forest of the entire province where I work. I'll
> keep you up to date.
> Bye
> Chiara
Kirk R. Wythers	                                     tel: 612.625.2261
Dept. of Forest Resources                 fax: 612.625.5212
University of Minnesota      email: kwythers at umn.edu
