[GRASSLIST:2301] Re: Poor quality PNG file driver output
Markus Neteler neteler at itc.it
Wed Jan 21 05:59:30 EST 2004
On Mon, Jan 19, 2004 at 07:12:16AM +0000, Glynn Clements wrote:
> Jason Horn wrote:
> > As for re-compiling grass, I'm not sure if I could do it.  I am using
> > 5.0.2 off of the OpenOSX CD because I'm not an expert with UNIX.  It
> > was a two-day ordeal for me to get the gd library compiled and running
> > on my system.  However, I would try to compile it (and all the other
> > libraries that go with it) if I thought it would help.  So, for Hamish,
> > or anyone else who can help...
> > 1) Why do you think re-compiling would help?  I wouldn't want to waste
> > days on that endeavor if it wouldn't work.
> If the PNG driver was built using GD 1.x, it will use GD 1.x at
> run-time (or fail to run if GD 1.x can't be found). There isn't any
> way to make it use GD 2.x without re-compiling it.
> The quote from Markus' book:
> 	"If the Gd2.x library is installed the driver supports true
> 	color output"
> isn't entirely accurate. The determining factor is whether the driver
> was built with GD 2.x, not whether GD 2.x happens to be present on the
> system.
The next edition of the book will not have this sentence any more
as it is related to GRASS 5.3 (which contains a PNG driver without
the need of GD, thanks to Glynn Clements).
Markus Neteler
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
