[GRASSLIST:2319] Re: m.proj2
Thu Jan 22 02:21:39 EST 2004
> I'm trying to use m.proj2 to translate a point from latlong ed50 coord
> sistem to the italian sistem (gaus-boaga, rome40)
> I have some difficulties to write the sintax of the command....
> thank you...
m.proj2 in GRASS 5.0.3 isn't that great. It's a little better in 5.3 but
for what you want to do I'd suggest using the 'cs2cs' program from
PROJ.4.
http://www.remotesensing.org/proj
The PROJ.4 documentation will give you some insight into what to feed
m.proj2 as well.
Hamish
