[GRASSLIST:2338] Re: i.his.rgb
Markus Neteler neteler at itc.it
Fri Jan 23 04:20:56 EST 2004
On Thu, Jan 22, 2004 at 12:22:20PM -0800, Ian Macmillan wrote:
> Hi all, I have a problem that I can't quite figure out with i.his.rgb.  I have
> been manipulating landsat 7 data using the method described in the GRASS book.
> I am trying to add in band 8.  So far I can get this to work, in a number of
> different ways.  The way I have found to be the most successful (for retaining
> the colors that I want) is to enhance the contrast of all 4 bands using
> r.rescale, converting to his (i.rgb.his), and converting back to rgb (i.his.rgb
> with band 8 as intensity).  The problem is that a lot of "holes" appear in the
> final rgb files.
I don't think that the usage of r.rescale is a good idea. Like that
you are manipulating the pixels instead of the color table.
Why not applying the HIS/RGB procedure and then using r.colors on
the resulting 3 channels?
>  Single pixels seem to be converted to a value of zero, even
> though the same pixels (in space) are not zeros or nulls in the original files
> (pre i.rgb.his > i.his.rgb).  I have posted a specific example here.
Yes - probably due to r.rescale usage.
> www.uweb.ucsb.edu/~ian_macmillan/hisrgb.jpg
> Band1x is the i.his.rgb converted blue file, while bands 1,2,3,8 are the
> original rescaled files.  The black dots are clearly visible scattered
> throughout the image.  They each have a value of zero.
> Anybody have any ideas what is going on?
It's not the procedure proposed in the book (there r.colors is recommended).
IMHO pixel values should not be touched.
Cheers
 Markus
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
