[GRASSLIST:2339] Re: r.in.gdal segfault
Markus Neteler neteler at itc.it
Fri Jan 23 04:34:26 EST 2004
On Thu, Jan 22, 2004 at 08:15:19PM -0500, SWlab wrote:
> Hello list,
> I have some problems with "r.in.gdal":
> I run grass 5.0.3, compiled with the "--with-gdal" option, on a SuSE8.2 box.
> The gdal version is 1.1.9, compiled with "--without-jasper" and
> "--without-grass" options. [Both compiled OK, from 'clean' sources (viz,
> after a make distclean eachtime)]
> I try to import this ASCII DEM:
> http://new-gis.mannlib.cornell.edu/CUGIR_Data/data1/x42elu.dem.gz
> When I run
> r.in.gdal i=x42elu.dem o=dem lo=x42
> I get a segmentation fault.
Did you try 'gdalinfo'?
I have downloaded the file, and it reports:
gdalinfo x42elu.dem
Driver: USGSDEM/USGS Optional ASCII DEM
Size is 1041, 1395
Coordinate System is:
PROJCS["UTM Zone 18, Northern Hemisphere",
    GEOGCS["NAD27",
        DATUM["North_American_Datum_1927",
            SPHEROID["Clarke 1866",6378206.4,294.978698213898,
                AUTHORITY["EPSG","7008"]],
            TOWGS84[-3,142,183,0,0,0,0],
            AUTHORITY["EPSG","6267"]],
        PRIMEM["Greenwich",0,
            AUTHORITY["EPSG","8901"]],
        UNIT["degree",0.0174532925199433,
            AUTHORITY["EPSG","9108"]],
        AXIS["Lat",NORTH],
        AXIS["Long",EAST],
        AUTHORITY["EPSG","4267"]],
    PROJECTION["Transverse_Mercator"],
But, in fact I also get a segmentation fault (r.in.gdal from 5.3-CVS and
GDAL-CVS).
It crashes in wkt_to_grass() in main.c of r.in.gdal (crash
in line 1054: free( pszUnitsName ); ). Actually I don't know
why, maybe it does not fetch the projection info properly.
> Other formats seem to be imported without trouble (GeoTIFF, for example).
> FYI, the same file is imported without trouble on a SuSE7.1 box, with
> grass5.0.2 and gdal1.1.9.
It seems to be related to USGS DEM only.
gdal_translate -of GTiFF x42elu.dem x42elu.tif
Input file size is 1041, 1395
0...10...20...30...40...50...60...70...80...90...100 - done.
r.in.gdal  in=x42elu.tif out=dem loc=demdem
 100%
CREATING SUPPORT FILES FOR dem
This works fine. So something runs odd when importing USGS DEM with
r.in.gdal.
> Any idea of troubleshooting more than welcome, it's rather frustrating...
> Thanks in advance
Unless it is fixed, you may use gdal_translate to convert the map to
GeoTIFF.
Regards
 Markus
