[GRASSLIST:2345] Re: NVIZ doesn't run
Andrew selkiesdad at twcny.rr.com
Fri Jan 23 08:08:46 EST 2004
perhaps you must go into your XF86config file and enable the module for
opengl by uncommenting the
Load "glx"
temiz wrote:
> hello
> I am using grass5.0.2 on slackware 9.1.
> Although I installed graphic card driver for OpenGL
> I received this message in using NVIZ:
> /http://www2.gis.uiuc.edu:2280/modviz/
> Loading Data
> Update elev null mask
> Loading Data
> translating colors from fp
> Adding panels from /usr/local/grass5/etc/nviz2.2/scripts
> Nv_(panels)
> toplevel made
> child killed: segmentation violation
>    while executing
> "exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f
> /usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script el=elv1 -name NVIZ
>  >&@stdout"
>    ("eval" body line 1)
>    invoked from within
> "eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
> $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $argv -name NVIZ
>  >&@stdout"
>    invoked from within
> "if {$argv == ""} {
> #no arguments
> $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdo..."
>    (file "/usr/local/grass5/bin/nviz" line 16)
> I will appreciate if anyone tells me the solution
> kind regards
> A.Temiz - TURKEY
> ______________________________________
> Inflex - installed on mailserver for domain @deprem.gov.tr
> Queries to: postmaster at deprem.gov.tr
> The views and opinions expressed in this e-mail message are the sender's
> own
> and do not necessarily represent the views and the opinions of
> Earthquake Research Dept.
> of General Directorate of Disaster Affairs.
> Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal
> olarak T.C.
> B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici
> nitelikte degildir.
