[GRASSLIST:2392] Re: scan-resolution for maps
Jan Hartmann jhart at frw.uva.nl
Thu Jan 29 08:09:20 EST 2004
As an addition to Wolfgang's excellent reply: it matters also whether
you scan in color, grayscale or black and white. Shannon's theorem is
directly applicable to black and white maps. I'm not sure about the
theory, but I think that with anti-aliased grayscale and color scans you
need a finer resolution. I had this experience with the original
cadastral maps of the Netherlands from 1832 (recently available on
www.dewoonomgeving.nl). Scanned parcel boundaries are not sharply
defined lines: pixel colors gradually flow over from line color to
background color. So even if lines on the map are approximately 1 mm
wide, a scanning resolution of 0.5 mm is not accurate enough.
FYY, I scanned some twenty historical maps of Amsterdam, mostly black
and white at 800 dpi, giving a street resolution of up to 10 cm. This is
way beyond Shannon's requirement, but it makes it possible to rectify
local parts of them very accurately. For larger overviews you can always
resample. BTW, GRASS does a very good job with these large rasters.
Jan
Wolfgang von Hansen wrote:
> "E. Koster" <niwlered at hotmail.com> schrieb am 28.01.04 18:01:40:
>>I remember from several years ago (grass4.x) there was a document from Cerl
>>talking about resolution and accuracy of maps. [...] Could you please
>>send me a reference, or introduce me to any other literature on this
>>subject?
> I don't know that document but it is not too difficult to calculate scan resolution based on some simple assumptions. The only difficulty involved is that most scanners need the resolution in dpi whereas real world units are usually metric.
>>the map I want to scan was created in 1639 using a copper-plate. The
>>instrument used to engrave can make lines up to a 0.1 mm in width. The
>>resolution of the map is 1:2.400.
> Actually, 1:2400 is *not* a resolution but a scale. BTW, it is not easy to define resolutions for analog products because these have something like an infinite resolution (but still only a limited accuracy).
>>At what resolution I should scan not to
>>have an overkill of information?
> You gave two different types of information, so one can define two different formulae to compute a scan resolution. The easier and better one is the line width:
> There exists a well know sampling theorem (by Shannon) which states that in order not to loose any vital information, one has to sample with twice the maximum frequency of the data. In your case these are pixels of 0,05 mm size. With 1 in = 25,4 mm the result is 25,4 / 0,05 dpi = 508 dpi.
> The other information is the scale of the map that relates the size of real world objects to the size of their cartographical representation. In order to find a scan resolution one has to define the real world area corresponding to one pixel of the result. Let us assume that a pixel size of 50 cm is sufficient to display everything but also necessary for the geometrical precision. This means that one pixel is 50 cm / 2400 = 0,21 mm. According to the above formula this results in 122 dpi.
> Now you have got a range of possible scanner settings where you can choose values from. Of course, you'll have to see whether the 50 cm of the second formula make sense for your application. In any case, more than 508 dpi is not necessary to reproduce the map.
> HTH,
> Wolfgang
> ______________________________________________________________________________
> Erdbeben im Iran: Zehntausende Kinder brauchen Hilfe. UNICEF hilft den
> Kindern - helfen Sie mit! https://www.unicef.de/spe/spe_03.php
