[GRASSLIST:2411] Re: grass53 compilation
Glynn Clements glynn.clements at virgin.net
Fri Jan 30 11:50:47 EST 2004
Michele wrote:
> Hi, trying to compile grass53 i get the following errors:
>    GRASS GIS source code compiled.
>    Compilation error in module: src/raster/r.in.gdal (ignored)
>    Compilation error in module: src.contrib/GMSL/g3d (ignored)
>    Compilation error in module: src.contrib/DUKE/r.terraflow (ignored)
> is it due to the compiler version as the problem in grass57?
> is it possible fom me to fix this changing  few parameters in the sources?
It's hard to say without seeing the actual error messages from "make".
Glynn Clements <glynn.clements at virgin.net>
