[GRASSLIST:3951] Re: tk.h/grass5.3/mdk10
Glynn Clements glynn.clements at virgin.net
Sun Jul 18 12:11:49 EDT 2004
Maciek Sieczka wrote:
> There where no errors wich would stop the building and all the stuff seems
> to be working fine, even NVIZ, great. But I found two errors in the
> "configure" log:
> configure:4260: error: too many arguments to function `setpgrp'
> configure:5178: error: structure has no member named `maxy'
> and a few warnings there too (and plenty of warnings in the "make" log)
> Should I be concerned?
No. Many of the errors which appear in config.log are to be expected,
including both of the above. Errors only matter when they result in a
test failing, in which case the configure script will display an error
message to the user.
Glynn Clements <glynn.clements at virgin.net>
