[GRASSLIST:3990] Re: ps.map grid in Lat/Lon
Ian MacMillan ian_macmillan at umail.ucsb.edu
Thu Jul 22 03:15:00 EDT 2004
I had a similar problem back with GRASS 5.0.0.  I was told at the time
that ps.map did not support floating point grids, hence the problem
with lat-long locations.  I don't know if it has been fixed, but a
simple workaround is to make a vector grid with v.mkgrid and just
display that along with whatever else you want with ps.map.  Thanks to
whomever suggested that to me.
Good luck,
Ian
On Jul 21, 2004, at 11:49 PM, Florian Goessmann wrote:
> hi everybody!
> i'm want to  overlay a map of a Lat/Lon location with a grid that has
> less than 1 degree spacing.
> is that possible? (geogrid is not available for lat/lon and if i use
> grid nothing happens when i choose a spacing less than 1)
> regards,
> Florian
