[GRASSLIST:3587] Re: script for importing Terra-ASTER data
Zbigniew Perski perski at us.edu.pl
Thu Jun 3 16:07:39 EDT 2004
Michael,
Thanks a lot. Last two days I have intensively tested your script with
the L1A data which I have. Your script is working now very fine without
any error.
For me the script comes really in right moment and speeds up my work a lot.
Thanks a lot again!
Zbigniew.
Użytkownik Michael Barton napisał:
> Zbigniew,
> I updated the r.in.aster script to read Level 1A ASTER imagery. I have
> a set and have tested it. It seems to work fine. I include a copy
> here. I am also posting it on my website in a new GRASS script
> exchange that I am going to launch (with some trepidation) in a
> followup posting. Thanks for your help in testing this.
> Michael Barton
> ______________________________
> Michael Barton, Professor & Curator
> School of Human Origins, Cultures, & Societies
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> voice: 480-965-6262; fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> On May 28, 2004, at 2:23 PM, Zbigniew Perski wrote:
>> Dear Paul,
>> As I did, you are trying to georeference subdataset 1. This is NOT
>> image band 1. This is the metadata and GCP's for image bands 1-3 VNIR.
>> So, now I understand my frustrations!
>> To actually georeference image band 1, you need to indicate
>> subdataset 2. The relationship between images and subdatasets is
>> listed at the bottom of the output to gdal-info. In brief, it is
>>> band 1=subdataset 2, 2=3, 3n=4, 3b=5, 4=8, 5=9, 6=10, 7=11, 8=12,
>>> 9=13, 10=16, 11=17, 12=18, 13=19, 14=20. Subdatasets 1, 5, 6, 7, 14,
>>> and 15 are reserved for metadata and GCP's.
>> OK.
>>> If Level 1A can be georeferenced, I can easily make the change to
>>> the script to let you select them via a flag.
>> This I think will be helpfull for many people since L1A data are more
>> frequent in ASTER database (as I remember 2 years ago L1B was realy
>> rare.).
>>> Also, I suspect that MODIS images work much the same way as they
>>> come from the same organizations and use the same hdf format. If so
>>> and someone could send me the output of gdal-info for a MODIS image,
>> For MODIS not, but for ASTER 1A I can send you some outputs in monday
>> if you wisch. I Have not MODIS data in this moment.
>>> I could try to either include MODIS in an expanded r.in.aster or
>>> make a companion r.in.modis.
>> It will be great too I think!
>> Many thanks
>> Zbigniew
