[GRASSLIST:3654] Re:
Glynn Clements glynn.clements at virgin.net
Thu Jun 10 04:32:46 EDT 2004
boli wrote:
> I have installed cygwin and grass5.0.2 under windows2000, but when I
> use the command grass5 -tcltk, a popup dialog said "libX11.dll not
> found". What is wrong? In fact, I can not find libX11.dll in my
> computer.
For a start, you need to install Cygwin's XFree86 packages in order to
use tcltkgrass or NVIZ.
Also, /usr/X11R6/bin needs to be in Cygwin's PATH setting.
Glynn Clements <glynn.clements at virgin.net>
