[GRASSLIST:3666] Re: gmake5 in grass57
Daniel Isenegger disen at geo.unizh.ch
Tue Jun 15 08:19:25 EDT 2004
> Hamish schrieb:
>>> i successfully installed grass5.7, with the sources of 5.3 (after
>>> working with grass 5.0.3) on a suse8.2.
>>> Now i tried to run own code with grass5.7  as i did with in 5.0.3
>>> using the gmake5 for compiling,
>>> but i cannot find a similar gmake5-file (as in 5.0.3) for the
>>> grass5.7.
>>> My questions are now:
>>> - Does i have to install grass5.3 for working with own code addressing
>>> tools in grass5.7
>> you only need 5.3 for the make 'mix step' .. after that you don't need
>> it anymore.
>>> - how can i get a appropriate gmake5 for grass5.7?
>> use 'make' instead; copy a Makefile from another similar module & modify
>> to suit.
>> Hamish
Hi
i renamed the Gmakefile to Makefile (cause i got no other Makefile):
CC=g++
# include of dirs, e.g.gis.h is in ...
CFLAGS=-g -Wall
EXTRA_CFLAGS=-I
/data/gis/nfp48/nfp48/ipodlas0.1/grass/grass57/grass57/include
# including of libs: e.g. D_ are in DISPLAYLIB
# order of libs: important -> DISPLAYLIB before RASTERLIB before GISLIB,etc
LIBES=$(DISPLAYLIB) $(RASTERLIB) $(IMAGERYLIB) $(VASKLIB) \
   $(GISLIB) $(DATETIMELIB) $(CURSES) $(XDRLIB) $(MATHLIB) $(SEGMENTLIB)
DEPLIBES=$(DEPIMAGERYLIB) $(DEPGISLIB) $(DEPVASKLIB) $(DEPVASK)
OBJ=main.cc plotRasterMap.cc
all: plotRasterMap
#with -g: gdb enabling option
plotRasterMap: $(OBJ) $(LIBES) $(DEPLIBS)
   $(CC) $(LDFLAGS) -g -o $@ $(OBJ) $(LIBES) $(DEPLIBES)
$(LIST): global.h
$(LIBES): #in case of library change;i.e.they must be here,
$(DEPLIBS):
# to clean up
.PHONY: clean
clean:
   rm *.o *~ ~* *@ \#*
and get errors now starting with:
... undefined reference to `G_gisinit'
(going on with similar errors concerning G_ and R_ functions)
I guess this means either a library is missing or the order is wrong in
LIBES, but i cannot figure out what.
Thanks dani
