[GRASSLIST:3683] Re: gmake5 in grass57
Glynn Clements glynn.clements at virgin.net
Wed Jun 16 09:32:14 EDT 2004
Daniel Isenegger wrote:
> > > > use 'make' instead; copy a Makefile from another similar module & modify
> > > > to suit.
> > > i renamed the Gmakefile to Makefile (cause i got no other Makefile):
> > That won't work. The syntax of a 5.7 Makefile is completely different
> > to that of a Gmakefile.
> > Copy a Makefile from a similar module and modify it.
>  Hi thanks for your advice,
> but i didn't succeed to move a step forward:
> 'Copy a Makefile from a similar module and modify it.'
> a makefile from grass57 module? Like e.g. the display/d.erase/Makefile?
Yes. To simplify matters, use a Makefile from a module which has a
similar set of dependencies. E.g. if you need to use the
raster/display libraries, use a Makefile from one of the display/d.*
modules.
> (there I'm stuck with the include-line and its further invocations
> (Module.make))
What do you mean by "stuck"? All modules (programs) need the line:
	include $(MODULE_TOPDIR)/include/Make/Module.make
This includes all of the common definitions, along with the settings
which are generated by the configure script.
In earlier versions, the gmake script concatenated a set of files (one
of which was the Gmakefile) to produce the final Makefile. In 5.7, we
just use the "include" directive instead.
> However, i tried with different version of Makefiles
None of which look remotely like any of the 5.7 Makefiles, which
suggests that you aren't copying an existing Makefile.
Glynn Clements <glynn.clements at virgin.net>
