[GRASSLIST:3735] Re: v.in.ogr and v.out.ogr
francesco francesco.pirotti at unipd.it
Tue Jun 22 00:18:35 EDT 2004
I figured what was wrong with exporting grass to postgis:
The error
  ERROR 1: AddGeometryColumn failed for layer mamma, layer creation has
  failed. ERROR: Cannot create layer
come up because I had a database and a schema with the SAME name!!  Bad
idea, I know.
I changed the schema name (ALTER schema <name> RENAME <new name>) in
postgresql 7.4.1 and everything worked fine. It defaults to the schema "public"
I wonder if there is a way to specify a schema in v.out.ogr?!
Thanks for the help
Francesco Pirotti
