[GRASSLIST:3737] compiling grass-5.7.0 - unable to locate lex
Sabine Grabner csab7771 at uibk.ac.at
Tue Jun 22 09:27:16 EDT 2004
hello
i would like to compile the new version of grass-5.7.0 but the first problem
rises with ./configure.
ueberflieger:/usr/local/grass-5.7.0 # CFLAGS="-g -Wall" ./configure
checking host system type... i686-pc-linux-gnu
checking for gcc... gcc
checking whether the C compiler (gcc -g -Wall ) works... yes
checking whether the C compiler (gcc -g -Wall ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for full floating-point support... yes
checking for pwd... /bin/pwd
checking for source directory... /usr/local/grass-5.7.0
checking for build directory... /usr/local/grass-5.7.0
checking how to build libraries... shared
yes
checking for ranlib... ranlib
checking how to run the C preprocessor... gcc -E
checking if 64bit support is requested... no
checking if 64bit Sparc VIS support is requested... no
checking system version (for dynamic loading)... Linux-2.4.21-166-default
checking for dlopen in -ldl... yes
checking for ar... ar
checking for SysV... no
checking for another button... no
checking for XDriver... socket
checking for additional include dirs...
checking for additional library dirs...
checking for a BSD compatible install... /usr/bin/install -c
checking for flex... lex
checking for yywrap in -ll... no
checking for lex... no
configure: error: *** Unable to locate lex.
how to continue?
thanx, sabine
