[GRASSLIST:3755] Re: v.digit and raster as background
Martin Wegmann mailinglist2_wegmann at web.de
Sun Jun 27 06:45:25 EDT 2004
On Sunday 27 June 2004 12:35, Martin Wegmann wrote:
already found a mistake -- changed vector names, now it should be fine
> # digitize a new vector and using the first vector and the raster image as
> background
> d.erase # clear monitor
> v.digit -n map=name_of_second_vector bgcmd="d.rast
> map=name_of_your_raster; d.vect=name_of_new_vector"
> #v.digit GUI appears and the layer defined in the "bgcmd=" settings are
> displayed in the background. The "bgcmd=" settings have to be seen as a
> series of commands separated with ";", therefore the last command "d.vect"
> displays the previously created vector on top of the raster image.
Martin
