[GRASSLIST:3762] Re: GRASSLIST digest 1419
Daniel Isenegger disen at geo.unizh.ch
Mon Jun 28 05:33:04 EDT 2004
>On Fri, Jun 25, 2004 at 06:01:53PM +0200, Radim Blazek wrote:
>>On Friday 25 June 2004 17:43, Daniel Isenegger wrote:
>>>Hi
>>>i'm working on a suse 8.2 with grass57 (compiled from source) on a local
>>>Grass-DB:
>>>with:
>>>db.connect -p
>>>driver:dbf
>>>database:/data/gis/nfp48/nfp48/ipodlas0.1/grass/grassdata/UpperEngadine/dis
>>>en/dbf
>>>db.select-statement works well
>>>(echo "select defoliatio from defoliation_53_shp" | db.select)
>>>but db.execute statements fail, e.g.:
>>>echo 'create table test_table ("cat" int, "desc" text)' | db.execute
>>'text' is not supported by DBF, column names should not be quoted, try
>>echo 'create table test_table (cat int, desc varchar(50))' | db.execute
>Also this suggestion fails (also the command given in the man page):
>DBMI-Postgres driver error:
>Cannot execute:
>ERROR:  parser: parse error at or near "desc" at character 35
>WARNING: Error while executing: "create table test_table (cat int, desc
>         varchar(50))
>(here: PG driver)
>I don't know how to debug it...
Hi
hm, somehow strange:
create table test_landcover (cat int, desc varchar(30))
works.
but  further operations fail, like (tried this with several variations
of quotations and escape-chars):
GRASS 5.7.cvs > echo 'insert into test_landcover values ('1', 'forest')'
| db.execute
DBMI-DBF driver error:
SQL parser error in statement:
insert into test_landcover values (1, forest)
Error in db_execute_immediate()
WARNING: Error while executing: "insert into test_landcover values (1,
         forest)
or on a existing table:
echo 'ALTER TABLE defoliation_53_shp ADD GRASSRGB varchar(30)' | db.execute
dbmi: Protocol error
WARNING: Error while executing: "ALTER TABLE defoliation_53_shp ADD
Broken pipe
>>>also db.driver fails with the error:
>>>error: can't read "opttype(1)": no such element in array
>>db.drivers -p ? Command line or GUI?
>The GUI version gives that error.
>Markus
exactly: on the GUI it fails. On the command line, this is fine.
db.drivers -p
dbf
shp
odbc
pg
ogr
Dani
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20040628/5c3ecdf5/attachment.html
