[GRASSLIST:3775] Re: unable to initialize GDAL bridge
Michael Barton michael.barton at asu.edu
Tue Jun 29 01:30:41 EDT 2004
On Jun 28, 2004, at 10:01 PM, Multiple recipients of list wrote:
> Hi, I'm a grass beginner and am running into a problem with
> r.in.gdal.  Whenever I try to import a file, I receive the following
> error:
> GBBridgeInitialize() failed to find an suitable GDAL .DLL/.so file.
>  The following filenames were searched for:
>    o libgdal.1.1.so
>    o gdal.1.0.so
>    o gdal.so.1.0
>    o libgdal.so.1
>  The following locations were searched:
>    o /usr/local/grass53/lib
>    o System default locations.
Grant,
Try downloading the GDAL at Rich Greenwood's site (www.
greenwoodmap.com). Rich maintains binaries of GRASS for Cygwin. I
believe that he has a binary GDAL for windows, including the needed
*.dll.
Here is what one of my student's worked out this past Spring about
where it needs to go.
>> Yes, I got r.in.gdal to work.  Here is what I had to do:
>> -->Place the libgdal.1.1.dll file into WINNT/system folder
>> - then I got an error that "cygjpeg-62.dll" wasn't found,
>> -->so I reinstalled the jpeg library from cygwin
>> - then I got an error that "cygcrypto-0.9.7.dll" couldn't be found,
>> -->so I had to reinstall the openssl/openssl-0.9x libraries (I chose
>> all three
>> or so of them)
>> Then GRASS r.in.gdal decided to work for me.  Now I just have to
>> figure out
>> which data I actually wanted to import with this!
>  ERROR: Unable to initialize GDAL bridge (check libgdal
>         installation/LD_LIBRARY_PATH variable).
>  mail: not found
> I am running Grass53 in Cygwin in Windows XP Pro.  The version of GDAL
> that I built from source is 1.2.1.  Thanks in advance.
Hope this is helpful
____________________
C. Michael Barton, Professor
School of Human Origins, Cultures, & Societies
PO Box 872402
Arizona State University
Tempe, AZ  85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20040628/8b4d9eba/attachment.bin
