[GRASSLIST:2802] Re: dxf-shp-v.digit
Radim Blazek
blazek at itc.it
Tue Mar 2 09:45:19 EST 2004
On Wednesday 25 February 2004 11:20, Bettina wrote:
> Hello
> I would like to insert a dxf-file in GRASS GIS 5.0.3.
> I have loaded the "Layer with Line data" via v.in.dxf, which I can see on
> the monitor.
> How I can load layer with texts from a dxf file. At the moment, I can just
> see contour lines.
> Another problem:
> I tried to insert a shp-file in GRASS GIS 5.7
> The following error message appears:
> v.in.ogr: relocation error: v.in.ogr: undefined symbol: OGRGetDriverCount
> Does anyone knows where this error comes from?
Do you have GDAL >= 1.1.8?
BTW, v.in.dwg can import both DWG and DXF.
> My last question:
> I labeld some areas (v.digit) ? entered a category number and edit the
> category file in v.support.
> Now I can see the category number when I run v.digit.
> How can I make the given name visible?
In v.digit you cannot AFAIK. In 5.7 you can use d.vect display=attr
or generate labels (v.label).
Radim
