[GRASSLIST:2917] Re: text
Radim Blazek blazek at itc.it
Fri Mar 12 04:02:47 EST 2004
On Wednesday 10 March 2004 23:32, Hamish wrote:
> > And how does it work in GRASS 5.7?
> v.in.dwg should be much better than v.in.dxf, but unfortunately it is
> based on a non-Free library and you'll have to build it yourself if you
> want to try. You may not distribute the resultant binary program.
> I have no idea if it will deal with text layers.
Text element is imported as point + text stored in attribute table.
Radim
