[GRASSLIST:3026] m.proj2 input file format
Martin du Saire mdusaire at umn.edu
Wed Mar 24 13:09:42 EST 2004
Help.
I am attempting to use m.proj2 to transform lat/lon data to eqdc projection
(Equidistant Conic).  Command line seems to work fine:
 >-100 45
-628278.882116  362641.875369
However with an input file...
Input file:
45 0 0.0 -100 0 0.0
Output file:
11723467.724040 7394856.374043 0.0 -100 0 0.0
Now what am I doing wrong?
Thanks.
Martin
In case there is something conceptually wrong, I have included the
input/output projection parameters I am using.
Input projection parameters:
ll
Ellipsoid: GRS80
Output projection parameters:
eqdc
Ellipsoid: GRS80
Ref Lat: 42N
Std. parallel 1: 37N
Std. parallel 2: 47N
Central meridian: 92W
Units: meters
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20040324/79281b0c/attachment.html
