[GRASSLIST:3060] Problems with TclTk
Gerry James
gjames at bgcengineering.ca
Tue Mar 30 11:06:15 EST 2004
I have recently downloaded the Grass 5.0.3 binaries and loaded them on a
Fedora Core server. The text interface works well however when I type in
tcltkgrass& from within Grass I get the following error message:
/root/grass5/tcltkgrass: line 3: /wish: no such file or directory
/root/grass5/tcltkgrass: line 3: exec: /wish: cannot execute: no such file
or directory
Do I need to reinstall Tcl/Tk or is there another solution. Can anyone
help.
Thanks
Gerry James
-----Original Message-----
From: owner-GRASSLIST at Baylor.edu [mailto:owner-GRASSLIST at Baylor.edu]On
Behalf Of Lorenzo Moretti
Sent: Tuesday, March 30, 2004 4:39 AM
To: GRASSLIST at Baylor.edu
Subject: [GRASSLIST:3058] Re: Problems with TclTk Aqua
>Hi folks,
>I recently downloaded the GRASS 5.3 and 5.7 binaries for OS X. I
>must say that I am impressed by how they're shaping up. I am having
>one problem. I also installed TclTkAquaBi-8.4.5. Afterwards, when
>I launch GRASS 5.3, the Wish Shell crashes. When I try the
>tlctkgrass& I get the following message:
>Error in startup script: window name "loading" already exists in parent
> while executing
>"label .loading -text {Loading ...}"
> (file "/Applications/Grass/grass53/tcltkgrass/main/gui.tcl" line 1881)
> invoked from within
>"source $env(TCLTKGRASSBASE)/main/gui.tcl"
> invoked from within
>"if [catch {source $env(TCLTKGRASSBASE)/main/gui.tcl}] {
> set env(TCLTKGRASSBASE) $env(GISBASE)/tcltkgrass
> source $env(TCLTKGRASSBASE)/main/gui...."
> (file "/Applications/Grass/grass53/bin/tcltkgrass" line 26)
>GRASS 5.7, on the other hand, will launch, but when I try to display
>a map I get:
>Error: channel "console1" wasn't open for writing
>Then the buttons OK Skip Message and Details.
>Does anyone have any ideas on what is wrong and how to fix it?
>Sincerely
>Kurt Springs
Hi Kurt
Tcltk for Acqua does not work with my GRASS OS X. My Grass use Tcltk
for Unix (included in Grass Libraries) . Im my OSX distribution there
is all: you just have to install Apple's X11. Tcltk for Acqua DOES
NOT WORK with my Grass.
Markus write
>At time these binaries consume more than 150MB. Once compiled
>with shared libraries the size should be significantly smaller
>and we could host them.
From my grass 5.3 compiled with shared libraries I will have these size:
now with shared
GRASS GIS COMPLETE 158 MB 93 MB
grass53 single package 74 MB 11 MB
Bye
________________________________________________________________________
|| Lorenzo Moretti e-mail: lorenzo.moretti at bologna.enea.it
||/|/| ENEA prot/idr Web: http://wwwamb.bologna.enea.it/
|| | via Don Fiammelli, 2 FTP: ftp://ftpamb.bologna.enea.it/ (res.)
~~~~~~ 40128 BOLOGNA - ITALY Ph: +39-0516098086 Fax: +39-0516098131
Download GRASS for MAC OS X:
http://wwwamb.bologna.enea.it/forgrass/
