[GRASSLIST:3321] v.proj error from GRASS 5.3 Linux build
Thomas Adams Thomas.Adams at noaa.gov
Sat May 1 11:31:54 EDT 2004
Paul, et al,
I have built GRASS 5.3 for Linux from source along with gdal-1.2 and
prog.4 ver 4.4.7. The builds for all of these produce NO ERRORS except
when I attempted to 'make install' gdal-1.2, which gave me errors
related to pymod gdal libraries and needing to "relink" _gdalmodule.la.
But, GRASS 5.3 did build & install with no errors.
When I attempt to use v.proj, I get the following error:
v.proj: relocation error: v.proj: undefined symbol: pj_set_finder
Any ideas what is going on?
Regards,
Tom
Paul Kelly wrote:
>On Fri, 30 Apr 2004, Thomas Adams wrote:
>>Glynn,
>>I'll heed your advice. At this point would I be better off going to
>>GRASS 5.3 (which I understand is still under development)
>IMHO being under development is a good point as it means bugs are being
>fixed. I would highly recommend to use 5.3.
>I said to Helena that if no-one else does, on 15 May I will tag the CVS
>head and prepare a 5.3.0 source code release containing the content of the
>CVS head as of that day.
>Paul
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL:	thomas.adams at noaa.gov
VOICE:	937-383-0528
FAX:	937-383-0033
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20040501/71de9855/attachment.html
