[GRASSLIST:3325] Re: v.proj error from GRASS 5.3 Linux build
Thomas Adams Thomas.Adams at noaa.gov
Sat May 1 12:58:48 EDT 2004
Paul,
That did it! Many thanks; it's also good to see from the discussion with
Michael Barton that the *rcommended* path to go at this point is GRASS
5.3. BTW, I decided to build 5.3 without PROJ.4 -- that seemed to be the
best way to go.
Thanks again.
Cheers!
Tom
Paul Kelly wrote:
>On Sat, 1 May 2004, Thomas Adams wrote:
>>Paul, et al,
>>I have built GRASS 5.3 for Linux from source along with gdal-1.2 and
>>prog.4 ver 4.4.7. The builds for all of these produce NO ERRORS except
>>when I attempted to 'make install' gdal-1.2, which gave me errors
>>related to pymod gdal libraries and needing to "relink" _gdalmodule.la.
>>But, GRASS 5.3 did build & install with no errors.
>>When I attempt to use v.proj, I get the following error:
>>v.proj: relocation error: v.proj: undefined symbol: pj_set_finder
>>Any ideas what is going on?
>Make sure your external PROJ.4 is installed properly (shared library
>directory in LD_LIBRARY_PATH env var or in /etc/ld.so.conf and run
>/sbin/ldconfig).
>Or:
>don't use an external PROJ.4. This is the default (--with-proj=no) for 5.3
>and should work as well if not better than the remotesensing.org PROJ.4.
>Paul
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL:	thomas.adams at noaa.gov
VOICE:	937-383-0528
FAX:	937-383-0033
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20040501/cbbdafab/attachment.html
