[GRASSLIST:3355] Re: Compilation error in module:src/raster/r.in.gdal (ignored) SOLVED !
DrakeGis drakegis at dacafe.com
Tue May 4 23:57:44 EDT 2004
Thanks you Hamish !!!!!!!!!!!
The module is available rigth now !!!
 Drake
>> I download and compile Grass 5.0.3, and I recieve this message, after
>> the compilation. here is my error.log
>> GRASS GIS compilation log
>> Start of compilation: Tue May  4 05:38:31 EDT 2004
>> Errors:
>> Compilation error in module: src/raster/r.in.gdal (ignored)
>> End of compilation:   Tue May  4 05:42:01 EDT 2004
>> DONE generating GRASS GIS binary code
>> I try with
>> ./configure --with-gdal
>> ./configure --with-gdal='/usr/local/bin/gdal-configure'
>> ./configure --with-gdal='/usr/local/bin'
> --with-gdal checks /usr/local automatically, and if path is used, it
> should include the executable as on your second line.
>> I have openev installed and it works. Also, I have libgdal1
>> # slocate libgdal
>> /usr/local/lib/libgdal.1.1.so
>> PS: I'm using Debian 3 SID, on a notebook Compaq Presario 2175US
> Install the following Debian packages. (you may need to remove the
> version in /usr/local if it doesn't work/crashes ?)
> gdal-bin - Geospatial Data Abstraction Library - Utility programs
> libgdal1 - Geospatial Data Abstraction Library
> libgdal1-dev - Geospatial Data Abstraction Library - Development files
> Hamish
This email was sent using http://cafemail.giscafe.com .
