[GRASSLIST:3376] Re: Set PNG resolution permanently
Glynn Clements glynn.clements at virgin.net
Fri May 7 21:27:51 EDT 2004
Ulrich Leopold wrote:
> I would like to set the PNG monitor resolution permanently in
> grass5.0.2.
> I changed my .grassrc to
> GRASS_WIDTH: 3200
> GRASS_HEIGHT: 2400
> GRASS_PNGFILE:map.png
> It does not work. I also tried to use '=' instead of ':'. I tried also
> after logging out from grass. No effects.
> Is it not possible at all to set it in .grassrc?
No. These three variables are environment variables, not GRASS
variables.
For bash, add the following to ~/.grass.bashrc:
	export GRASS_WIDTH=3200
	export GRASS_HEIGHT=2400
For csh/tcsh, add the following to ~/.grass.cshrc:
	setenv GRASS_WIDTH 3200
	setenv GRASS_HEIGHT 2400
Glynn Clements <glynn.clements at virgin.net>
