[GRASSLIST:3436] Re: new 53 osx compile
Kirk R. Wythers kwythers at umn.edu
Mon May 17 17:15:15 EDT 2004
Just to be though, has anyone else had trouble getting the module
d.text.freetype to compile. I updated grass53 today and am getting the:
  "GRASS GIS source code compiled.
Compilation error in module: src/display/d.text.freetype (ignored)"
error. The configlog look fine.
On May 17, 2004, at 3:07 PM, Michael Barton wrote:
> Kirk,
> I haven't compiled this in several months. You've probably checked the
> obvious, but do you perhaps the correct version of Freetype installed
> in a non-standard location and need to do a --with-libdir= or
> something similar in the ./config?
> I guess I'd check the config log first to see what is going on with
> freetype (where it is looking and where it wants to look, etc.).
Ya... I don't know. The config log looks fine. No problems with
freetype. I seem to remember that there was once an issue of whether
configure looked for freetype first in apple's X11 or fink... I've
tried both and doesn't seem to matter.
> Michael
> ______________________________
> Michael Barton, Professor & Curator
> School of Human Origins, Cultures, & Societies
> Arizona State University
> Tempe, AZ  85287-2402
> USA
> voice: 480-965-6262; fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> On May 17, 2004, at 12:50 PM, Kirk R. Wythers wrote:
>> Scott and Michael,
>> I'm writing you two because I figure you have as much experience on
>> this list with OSX compile issues as anyone. I just tried
>> re-compiling grass53 (both from after cvs and the new stable). One of
>> my troubles is that I don't do this often enough to keep track of all
>> the little "tricks" that I end up employing in oder to make it work.
>> In this case, I get the compile to finish, but I also have two
>> modules that show the "Compilation error in module:
>> src/display/d.text.freetype (ignored)" error
>> Any suggestions?
>> Kirk
>> Kirk R. Wythers	                                    tel: 612.625.2261
>> Dept. of Forest Resources                fax: 612.625.5212
>> University of Minnesota     email: kwythers at umn.edu
