[GRASSLIST:3464] Re: Geophysical/Potential field modules for GRASS?
Andrew selkiesdad at twcny.rr.com
Fri May 21 13:02:06 EDT 2004
I have designed a simple approach to scripting (bash and perl) and
running from witin the grass shell. I generate many (hundreds sometimes)
of filtered Bouguer surfaces satisfying different extent and filter
parameters in an iterative loop. It is easy to do, but I use the perl
and the GMT tools for reducing,  interpolating and filtering my raw
data. I import this into grass and set up some of the support files, all
from small master scripts. I found the fft/ifft modules in grass
awkward, having become accusomed to setting my filter parameters from
the command line in GMT, but I could probably figure out an equivalent
way using the grass tools in a script if I had to. I have ideas for a
module related to this, including perhaps color palette creation and
asignment support from a color-chooser like interface. I have a problem
where this would be useful. I am only a one-shot scripter, though,
myself. I don't think I could tackle this, even in Tcl/Tk.
Funkmeister wrote:
> Hello, I will need to process/interpret some geophysical data
> (gravity, mag) and I would like to use GRASS for this purpose. Is
> anyone aware of any modules available for GRASS? I need to do things
> like trend removal, terrian corrections, Bouguer correction, reduction
> to pole, downward continuation, etc. I will also need to apply any
> number of 2-D filters.
> If there are no suitable modules, I will likely write them. So please
> also let me know if anyone else is interested in such modules, and
> features that would be desired.
> Thank you,
> Craig
