[GRASSLIST:3539] Re: script for importing Terra-ASTER data
Andrey Kiselev dron at ak4719.spb.edu
Fri May 28 16:50:41 EDT 2004
On Fri, May 28, 2004 at 10:29:04AM -0700, Michael Barton wrote:
> script to let you select them via a flag. Also, I suspect that MODIS
> images work much the same way as they come from the same organizations
> and use the same hdf format. If so and someone could send me the
> output  of gdal-info for a MODIS image, I could try to either include
> MODIS in  an expanded r.in.aster or make a companion r.in.modis.
It is not possible if you mean MODIS Level 1B files. MODIS Level 1B GCPs
extraction is disabled in the source code because of many reasons. Those
GCPs shouldn't be used directly, there is complicated algorithm to
georeference that dataset. And that is not supported by the gdalwarp,
sorry.
						Andrey
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
