[GRASSLIST:3546] Re: Cross-compilation (curses)
Michael Barton michael.barton at asu.edu
Sat May 29 17:40:38 EDT 2004
I'm afraid that I can't help you. Perhaps you should send your query to
the grass user mail list
Michael Barton
____________________
C. Michael Barton, Professor
School of Human Origins, Cultures, & Societies
PO Box 872402
Arizona State University
Tempe, AZ  85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
On May 26, 2004, at 2:57 AM, nagaraju chilukuri wrote:
> I am Nagaraju.
>                 I was trying to Cross compile GRASS for an "arm" based
>                 machine.In that, while i was running configure it was
> asking for
>                 "curses".
>               So i started with cross compiling of curses.
>                 My GRASS is in /usr/local.
>                 wheni used "configure" command for ncurses ,finally it
> gave
>                  the following response
>                    ** Configuration summary for NCURSES 5.4 20040208:
>                                 bin directory: /usr/bin
>                                 lib directory: /usr/lib
>                                include directory: /usr/include
>                                man directory: /usr/man
>                                 terminfo directory: /usr/share/terminfo
>           From this i understood that it is not going for  /usr/local .
>          While i gave make (or) make sources it gave the following
>           response is given
>  root at localhost ncurses-5.4]# make sources
> cd man && make DESTDIR="" sources
> make[1]: Entering directory `/usr/local/ncurses-5.4/man'
> sh ./MKterminfo.sh ./terminfo.head ./../include/Caps ./terminfo.tail
> >terminfo.5make[1]: Leaving directory `/usr/local/ncurses-5.4/man'
> cd include && make DESTDIR="" sources
> make[1]: Entering directory `/usr/local/ncurses-5.4/include'
> cat curses.head >curses.h
> AWK=gawk sh ./MKkey_defs.sh ./Caps >>curses.h
> sh -c 'if test "chtype" = "cchar_t" ; then cat ./curses.wide
> >>curses.h ; fi'
> cat ./curses.tail >>curses.h
> sh ./MKhashsize.sh ./Caps >hashsize.h
> AWK=gawk sh ./MKncurses_def.sh ./ncurses_defs >ncurses_def.h
> AWK=gawk sh ./MKparametrized.sh ./Caps >parametrized.h
> gawk -f MKterm.h.awk ./Caps > term.h
> sh ./edit_cfg.sh ../include/ncurses_cfg.h term.h
> ** edit: HAVE_TCGETATTR 1
> ** edit: HAVE_TERMIOS_H 1
> ** edit: HAVE_TERMIO_H 1
> ** edit: BROKEN_LINKER 0
> make[1]: Leaving directory `/usr/local/ncurses-5.4/include'
> cd ncurses && make DESTDIR="" sources
> make[1]: Entering directory `/usr/local/ncurses-5.4/ncurses'
> sh ./base/MKlib_gen.sh "arm-linux-gcc -E -DHAVE_CONFIG_H -I../ncurses
> -I. -I. -I../include  -D_GNU_SOURCE -DNDEBUG" "gawk" generated
> <../include/curses.h | \
>         fgrep undef >../include/nomacros.h
> gawk -f ./tinfo/MKnames.awk ./../include/Caps
> cat namehdr boolnames boolfnames numnames numfnames strnames strfnames
> nameftr >names.c
> cat namehdr boolcodes numcodes strcodes codeftr >codes.c
> rm -f namehdr nameftr codeftr boolnames boolfnames boolcodes numnames
> numfnames
> numcodes strnames strfnames strcodes
> arm-linux-gcc -o make_hash -DHAVE_CONFIG_H -I../ncurses -I.
> -DHAVE_CONFIG_H -I../ncurses -I. -I. -I../include  -D_GNU_SOURCE
> -DNDEBUG -O2 -DMAIN_PROGRAM ./tinfo/comp_hash.c
> sh ./tinfo/MKcaptab.awk gawk ./../include/Caps > comp_captab.c
> ./tinfo/MKcaptab.awk: line 20: ./make_hash: cannot execute binary file
> ./tinfo/MKcaptab.awk: line 21: ./make_hash: cannot execute binary file
> sh ./tty/MKexpanded.sh "arm-linux-gcc -E" -DHAVE_CONFIG_H -I../ncurses
> -I. -I. -I../include  -D_GNU_SOURCE -DNDEBUG > expanded.c
> sh ./tinfo/MKfallback.sh /usr/share/terminfo ../misc/terminfo.src
> >fallback.c
> arm-linux-gcc -o make_keys -DHAVE_CONFIG_H -I../ncurses -I.
> -DNDEBUG -O2 ./tinfo/make_keys.c
> AWK=gawk sh ./tinfo/MKkeys_list.sh ../include/Caps | sort >keys.list
> ./make_keys keys.list > init_keytry.h
> /bin/sh: line 1: ./make_keys: cannot execute binary file
> make[1]: *** [init_keytry.h] Error 126
> make[1]: Leaving directory `/usr/local/ncurses-5.4/ncurses'
> make: *** [sources] Error 2
> >>>>Here I saw that it was trying to execute the "make_keys" file but
> it was unable to do that.
> Actually the binaraies are getting produces for the HOST(arm).
> I think that is why it is unable to execute.If  i thought something
> wrong ,
> Then please convey me what went wrong.
> So please suggest me some method to solve this problem.
> Thanking you,
>  Nagaraju
>  Yahoo! Messenger - Communicate instantly..."Ping" your friends today!
> Download Messenger Now
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20040529/b46e1d4a/attachment.bin
