[GRASSLIST:4726] Re: compile grass57 on cygwin
Paul Kelly paul-grass at stjohnspoint.co.uk
Sat Nov 6 14:33:26 EST 2004
Does --with-proj-libs=/usr/local/lib not help?
On Sat, 6 Nov 2004, [ISO-8859-1] "Molina Müller" wrote:
> Hi all,
> I installed grass57 on WinNT/cygwin. v.digit always crashes with
> "segmentation violation".
> So I'd like to compile grass57 myself.
> The required Proj.4 installation seems to be finished successfully
> (libproj.a and libproj.la in usr/local/lib).
> Running the configure script for grass57 exits with the following message:
> checking External PROJ.4 version... 449
> checking for location of External PROJ.4 library...
> checking for pj_get_def in -lproj... no
> configure: error: *** Unable to locate External PROJ.4 library.
> config.log says:
> configure:6571: checking for location of External PROJ.4 library
> configure:6596: checking for pj_get_def in -lproj
> configure:6613: gcc -o conftest -g -Wall     -Wl,--export-dynamic conftest.c
> -lproj   1>&5
> /usr/lib/gcc-lib/i686-pc-cygwin/3.3.3/../../../../i686-pc-cygwin/bin/ld:
> cannot find -lproj
> collect2: ld returned 1 exit status
> Could anybody give an advice? After days of trying I'm near to despairing...
> Thank you very much
> Molina
> NEU +++ DSL Komplett von GMX +++ http://www.gmx.net/de/go/dsl
> GMX DSL-Netzanschluss + Tarif zum supergünstigen Komplett-Preis!
