[GRASSLIST:4734] Re: v.in.ogr gives dbmi: db_open_database() not implemented
Huidae Cho grass4u at gmail.com
Mon Nov 8 00:25:22 EST 2004
We have the same problem on Cygwin in terms of the db error. You may
want to configure with --disable-shared.
./configure --disable-shared
make
Hope this helps.
Huidae Cho
On Sun, 07 Nov 2004 19:08:13 -0800, David Mahoney <mahoneyd at unbc.ca> wrote:
> Hi,
> I am running Mac OS X (10.2.8) and have compiled grass 5.7 (cvs).
> However, when I run v.in.ogr, I get this error
> GRASS 5.7.cvs:~/gisdata/grass_x/93f/93f037 > v.in.ogr dsn=tctr_037 \
> layer=LAB,ARC type=line out=tctr_037
> A datum name nad83 (North_American_Datum_1983) was specified without
> transformation parameters.
> WARNING: Non-interactive mode: the GRASS default for nad83 is
>           towgs84=0.000,0.000,0.000.
> Projection of input dataset and current location appear to match.
> Proceeding with import...
> WARNING: The vector 'tctr_037' already exists and will be overwritten.
> WARNING: Cannot open database
>           '/Users/dave/gisdata/grass/trim-utm10/dave/dbf'
>           '/Users/dave/gisdata/grass/trim-utm10/dave/dbf' by driver 'dbf'
> WARNING: Cannot get info if table 'tctr_037_1' linked to vector exists.
> ERROR: Cannot delete existing vector tctr_037
> Is this a GDAL problem?
> Thanks,
> Dave
