[GRASSLIST:4777] Re: r.in.tiff: problems
William K woklist at charter.net
Thu Nov 11 11:27:55 EST 2004
Probably because MacDEM saves a color TIFF - I think the defaults have
a blueish color for either the zero elevs or nulls. (it's been a while
since I used MacDEM)  Even if you could get it to save a grayscale
tiff, you'd still have to deal with the nulls somehow.
A better way to bring in SRTMs into GRASS is directly, using r.in.gdal.
Then use GRASS to patch them together.  There's been a few queries
about it on the list recently - check the archives.  Maybe when I have
time to figure out the new wiki I'll add something there.
On Nov 11, 2004, at 4:25 AM, lawrence moran wrote:
> Hi,
> Thanks to those who helped with my previous query- I'm now getting
> somewhere!
> Next I'm trying to bring in some SRTM topographic data. I've used
> MacDEM to merge 4 degree squares and exported these as a tiff with
> world file. Using r.in.tiff, I get three bands (.r, .g, .b). However
> band .r displays as null values, .g and .b display as greyscale.
> Any ideas what's going on?
> Thanks,
> Lawrence
William Kyngesburye <williamk at mappingspecialists.com>
Mapping Specialists <http://www.mappingspecialists.com>
Don't Panic
