[GRASSLIST:4780] Re: how can I compile grass-5.7.0 with blas(atlas)/lapack support?
acrux acrux_it at libero.it
Thu Nov 11 12:33:43 EST 2004
On Tue, 9 Nov 2004 15:59:17 +0000
glynn at gclements.plus.com wrote:
_omissis__
> First, the BLAS library has to be called libblas.* (i.e. it can be
> linked using -lblas).
> Second, I'm not sure whether anything can actually use BLAS/LAPACK at
> present. If those libraries are enabled, some additional functions are
> available in the gmath library. However, I'm not sure whether anything
> actually uses those functions.
ok, thanks for your help.
greetz,
vesuvio | LinuxMachine 156116
powered by GNU/Linux Crux
 # GnuPG/PGP Key_ID: 0x378EECB8
