[GRASSLIST:4864] Re: vector digitizing
ivan marchesini marchesini at unipg.it
Wed Nov 17 10:28:22 EST 2004
Hi...
I have noted that there is already a wish about my problem...
the text was this:
___________________________________________________________________
For the new v.digit in GRASS 5.7 I would like to see an elastic band
function
as it is implemented in the old v.digit in GRASS 5.0/5.3.
Digitizing long lines e.g. contour lines you always need to stop
digitizing,
then set a node, then use the pan function and start digitizing from the
node
again. For this an elastic band as in the old v.digit would be very
helpful.
thanks
____________________________________________________________________
this is exaclty what I need....   :-)
thanks for all answer....
ivan
Il mer, 2004-11-17 alle 07:43, Hamish ha scritto:
> On Tue, 16 Nov 2004 18:06:07 +0100
> ivan marchesini <marchesini at unipg.it> wrote:
> > Dear users...
> > I have a question that can be stupid but at the moment I didn't solved
> > the problem....
> > I need to digitize sone elements along a river... like banks, axis and
> > so on....
> > I would whant to use grass 57 and v.digit but I have a problem: I start
> > to digit and, when I arrive at the end of the dimension of the monitor
> > and I try to pan, the process stop... I can't continue to digit from
> > where I was arrived before.....
> > I remember it was possible using old v.digit..... when you arrive to the
> > margin of the monitor you can decide to pan using right button...
> > what about this with grass 57 ?????
> > thank you very much
> perhaps file a wish?
> http://grass.ibiblio.org/bugtracking/wish.html
> Hamish
