[GRASSLIST:4883] Re: r.mask in grass57
Paul Kelly
paul-grass at stjohnspoint.co.uk
Fri Nov 19 16:02:05 EST 2004
Any raster map can be used as a MASK. Just copy it to a raster named MASK.
0 and null cells are masked; all others are visible. This way is much
easier IMHO than using r.mask.
On Fri, 19 Nov 2004, Ann Marie Gorman wrote:
> Hi.
> I found several other people with the same question and no answer...
> Has r.mask been removed from grass57?
> If so, is there a workaround?
> Thanks,
> Ann Marie
> amg24 at case.edu
