[GRASSLIST:4897] Re: rasters reprojection UTM -> LAEA
Mon Nov 22 14:06:48 EST 2004
Rado Bonk wrote:
> How can I reproject the files from XY location with coordinates to LAEA
> location? r.proj refuses to reproject XY rasters into LAEA.
You can't project to or from XY locations. You need to use g.setproj
to change the projection to one which matches the data.
