[GRASSLIST:4908] Re: libogdi31.so
Markus Neteler neteler at itc.it
Tue Nov 23 03:36:46 EST 2004
On Tue, Nov 23, 2004 at 01:45:57AM +0000, Glynn Clements wrote:
> Sandro Klippel wrote:
> > > > installing the new version of GRASS (20-11) I see that there is a new
> > > > needed library (libogdi31.so) that is available only for Mandrake.
> > > > Is it a truly needed library or only a bug in the binary of the week?
> > > Probably the latter. Which programs/libraries require it?
> > GDAL compiled with OGDI.
> In that case, it should only be an issue for the GDAL library. Delete
> the libgdal binary which came with GRASS (from $GISBASE/lib) and
> install one which is compatible with your system.
If he used the 5.7 binaries from grass.itc.it there shouldn't be
any GDAL libs included. Otherwise please notify me.
Markus
