[GRASSLIST:4913] Re: QGIS + GRASS problem
Radim Blazek blazek at itc.it
Tue Nov 23 07:07:32 EST 2004
Kenlo Nishida wrote:
> Hi GRASS users,
> I am trying to use QGIS with GRASS support. All the installation of
> GDAL, GRASS5.7, and QGIS completed fine and I can invoke QGIS on
> the GRASS shell. However, when I try to add a GRASS raster layer on
> QGIS with the GRASS plug-in button, it refuses to do so giving a
> message which says:
>   (...GRASS raster dataset name...) is not a supported raster data source.
> Of course, the GRASS raster dataset appears fine on GRASS with d.rast
> command.
> The GDAL interface seems working fine both on GRASS and QGIS because a
> GeoTIFF dataset (Landsat data) could be imported to them.
> Can anyone kindly give me a crue to fix this problem?
> PC: Vine-Linux 3.0 on x86
> GRASS: installed from source (grass-5.7.0.tar.gz)
> GDAL:  gdal-1.2.3-mh2.rpm  gdal-devel-1.2.3-mh2
> QGIS:  installed from source (qgis-0.5.0.tar.gz)
Are you sure that your GDAL is compiled with GRASS support?
gdalinfo --formats
Radim
