[GRASSLIST:4941] Re: v.database
Radim Blazek blazek at itc.it
Wed Nov 24 11:39:49 EST 2004
Leonardo Lami wrote:
> I think there is no problem if you remove v.database.
> I do not remember if you resolved the problem about v.db.connect and schema.
> I think that there is problem to connect a vector with a table in a schema
> with v.db.connect.
Cannot you simply use table=myschema.mytable ?
Radim
