[GRASSLIST:4963] Re: libogdi31.so
Markus Neteler neteler at itc.it
Thu Nov 25 09:11:43 EST 2004
On Wed, Nov 24, 2004 at 04:14:35PM +0100, Markus Neteler wrote:
> On Tue, Nov 23, 2004 at 09:53:04AM +0100, Paolo Cavallini wrote:
> > -----BEGIN PGP SIGNED MESSAGE-----
> > Hash: SHA1
> > Ciao Markus.
> > Here it is.
> > GRASS from itc binaries (not compiled) on a Debian Sarge box, with GDAL from
> > Debian package.
> > Tried on a couple of machines, with identical results.
> > Thanks.
> > pc
> > At 09:34, martedì 23 novembre 2004, Markus Neteler has probably written:
> > > > Hash: SHA1
> > > > Hi,
> > > > installing the new version of GRASS (20-11) I see that there is a new
> > > > needed library (libogdi31.so) that is available only for Mandrake.
> Found it.
> After quite some debugging I found the problem:
> The recent change in the configuration to use -deps for GDAL
> introduces the "new" ogdi31 dependency:
> Platform.make:GDALLIBS            = -L/usr/local/lib -lgdal -lodbc -logdi31 -lgif -ljpeg -lpng -L/usr/local/lib -L/usr/local/lib/lib -lgrass5 -lz -lm -ldl -L/usr/lib -lpq
> grep dep-libs ~/grass57/configure.in
>   GDAL_DEP_LIBS=`"$GDAL_CONFIG" --dep-libs 2>/dev/null`
Above GDAL_DEP_LIBS trick has been reverted,
The new shapshot should be ok now. Please try again
and complain if needed:
 http://grass.itc.it/grass57/binary/linux/snapshot/
Markus
