[GRASSLIST:4496] Re: Bus Error in ps.map on Mac OS 10.3
J. Brian Adams brian.adams at fandm.edu
Sat Oct 9 10:03:01 EDT 2004
This is in Grass 5.7.
The first error was mine.  The colortable was not being printed because
it did not exist.  I went in and edited the cats file manually and the
colortable now prints. I used to do this with r.support, but this is
gone.
Nevertheless, it does do something a bit odd.  I ask for three columns
using cols 3 (there are six categories.)  It prints three on the first
row, two on the second and the last on a third.  It would be nice to
have two rows of three.
It still does not print the vector map.  I am new to playing with
vlines and vareas, so I still suspect that the problem is in my ps.map
input file.
Brian
On Oct 6, 2004, at 6:24 PM, Hamish wrote:
>> I am getting a bus error in ps.map when I try to print the
>> colortable.
>> Although it doesn't give an error, ps.map does not print the vector
>> maps either.  This is on Mac OS X 10.3.5
> This is two errors? 5.3 or 5.7? can you reproduce it using the
> Spearfish data set and file a bug report along with the exact input
> commands and terminal output?
> http://grass.ibiblio.org/bugtracking/bugreport.html
> http://grass.ibiblio.org/data.html
> Hamish
> _______________________________
> Do you Yahoo!?
> Declare Yourself - Register online to vote today!
> http://vote.yahoo.com
