[GRASSLIST:4553] Re: compiling GRASS 5.7.0
Glynn Clements glynn.clements at virgin.net
Fri Oct 15 10:39:21 EDT 2004
Ulrich Leopold wrote:
> The "const" is missing in "null-val.c". Can I simply replace e.g. all
> "CELL" by "const CELL" etc.?
The "const" was added on 2004/07/23, (revision 1.9 of null_val.c)
which suggests that your 5.3 source tree isn't up to date. Maybe
whoever generated the grass53_exp_2004_10_09 snapshot had a sticky
tag?
The current revision of that file is:
	/null_val.c/1.11/Mon Oct  4 17:03:31 2004//
If the snapshot includes the CVS directories, check the file
src/libes/gis/CVS/Entries (in 5.3). If that's correct, check that the
symlinks in the 5.7 tree point to the correct 5.3 tree.
Glynn Clements <glynn.clements at virgin.net>
