[GRASSLIST:4593] Re: Datum transform frustrations
Joel Peter William Pitt pittj2 at lincoln.ac.nz
Thu Oct 21 23:17:59 EDT 2004
Please excuse my brief bout of insanity, I just
realised one was in degrees and the other as decimal.
Doh!
> Now I have a slightly different (or maybe related) problem:
> The projection co-ordinates match when I use "d.where -d -w"
> for both nzmg and tmerc projections, but the longitude and
> latitude is way off (approximately, if not exactly, the same for both):
> 172.96917306E       43.87039362S
> When I use ArcMap it shows the same coordinates, but the correct
> lat/long values.
> Joel
