[GRASSLIST:4296] r.contour
Leonardo Lami lami at faunalia.it
Fri Sep 3 09:57:38 EDT 2004
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On grass-5.7.cvs-i686-pc-linux-gnu-28_08_2004 on debian
I tried to use r.contour on a kernel raster but I have this result:
GRASS 5.7.cvs:~ > r.contour input=fagiano_kernel step=0.00001 cut=0
output=fagiano_kernel
WARNING: The vector 'fagiano_kernel' already exists and will be
         overwritten.
Reading data.
Percent complete:  100%
FPRange of data:    min =  0.000000 max = 0.003658
Minimum level will be 0.000000
Maximum level will be 0.003650
Continue?(y/n) [y] y
Displacing data.
Total levels:  367   Current level:(it counts levels and then...)
Segmentation fault
If I want display it I see the vector but it say to me:
WARNING: coor files of vector 'fagiano_kernel at 2004_miglioramenti_zrv' is
         larger than it should be (232324 bytes excess).
WARNING: Cannot display areas, topology not available
I remember thath in the past I used r.contour without problem, but I am not
sure.
Thanks
Leonardo Lami
lami at faunalia.it            www.faunalia.it
Via Colombo 3 - 51010 Massa e Cozzile (PT), Italy   Tel: (+39)349-1310164
GPG key @: hkp://wwwkeys.pgp.net http://www.pgp.net/wwwkeys.html
https://www.biglumber.com
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
iD8DBQFBOHhS92hCyP73w7ARAko6AJoCw3UAHZjz8clQ69Vp37QW4yQDvwCdGbjj
k6IsbZKQkWcxMY/ZlirPBN4=
=6Jxr
-----END PGP SIGNATURE-----
