[GRASSLIST:4315] Re: catchment area
Guillermo Felipe gfmb at tutopia.com
Mon Sep 6 15:07:06 EDT 2004
You need the dem, and the following commands:
**r.watershed **elevation=*/yourdem /*drainage=*/yourdrainage ....
(please check for more parameters)
*d.rast and d.zoom to identify your basin outlet  coordinates...* (you
have to take a point on the stream)
/*r.water.outlet* *drainage=*/yourdrainage/ *basin=*/yournewbasin/
*easting=*/value/ *northing=*/value
later you can use r.stats , r.average or  r.report with yourbasin map.
too it´s very useful to use r.mask in other to get statistics from other
maps.
see you
guillermo
turek2 wrote:
> Hi,
> How can I calculate it in GRASS?
> Maciek
> Portal INTERIA.PL zaprasza... >>> http://link.interia.pl/f17cb
Este mensaje ha sido explorado con McAfee Webshield e500 Appliance y es seguro.
Instituto Alexander von Humboldt
