[GRASSLIST:4367] Re: v.to.db
Radim Blazek blazek at itc.it
Fri Sep 17 10:29:46 EDT 2004
On Friday 10 September 2004 16:42, Leonardo Lami wrote:
> Hi,
> I'd like to know if is it possible and how make this kind of operation in
> Grass.
> I have a vector linked to a table with this three fields: id, count, area,
> value and I'd like to update the field "value" with the result of this
> operation: "count" value / "area" value
> I tried to use v.to.db:
> v.to.db map=g_anfibi field=3 qfield=3 option=query col1=sum
> qcol="count/area" but the output message say:
> Reading data trom the map ...  100%
> Querying database ... DBMI-DBF driver error:
> SQL parser error in statement:
> SELECT sum(valore) FROM g_anfibi WHERE cat = 1
> Error in db_open_select_cursor()
This is possible but too complicated.
> I tried also:
> echo "UPDATE g_anfibi_sum SET sum=count/area" | db.execute
> Error in db_execute_immediate()
> WARNING: Error while executing: "UPDATE g_anfibi_sum SET sum=count/area
This is better.
For both, set of SQL functions depends on database used. Mathematical
operations are not supported in assignment (update) by DBF driver.
Radim
