[GRASSLIST:4392] Re: wrong in page (grass-mapserver) ?
temiz temiz at deprem.gov.tr
Wed Sep 22 04:52:27 EDT 2004
thank you for response
I looked at the code you gave me the address.
A new problem arises:
1.~~~~~~~~~
  in Class Reference:
int queryByPoint(pointObj point, int mode, double buffer)in the wiki's
example:
layer.queryByPoint( map, pnt, mapscript.MS_MULTIPLE, 180.0 )
is this map object redundant ?
2 ~~~~~~
when I try to get grass map value
it gives :
Warning: [MapServer Error]: msQueryByPoint(): No matching record(s)
found. in /var/www/htdocs/kar_pro9.php on line 136
Fatal error: [MapServer Error]: msSHPOpenFile():
(/usr/local/grass_Data0/f29/PERMANENT/cellhd/GENEL3) in
/var/www/htdocs/kar_pro9.php on line 137
how can I solve the problem ?
regards
Richard Greenwood wrote:
>Have you looked at the raster queries wiki:
>   http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?RasterQuery
______________________________________
Inflex - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster at deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20040922/50741bd6/attachment.html
